How often should I change the 5W-30 synthetic oil if I drive 5K miles a year?
Old 12-07-12, 01:22 PM
topgun129
topgun129's Avatar
Default How often should I change the 5W-30 synthetic oil if I drive 5K miles a year?
Hi,
How often should I have the 5W-30 synthetic oil changed in my 98 GS300 if I drive an average of 5K miles a year? The car currently has 108,460 miles on it and it has been 5694 miles since the last oil change.
Thanks!
Old 12-07-12, 03:42 PM
Mr Jokster
Mr Jokster's Avatar
You change it as often as it needs, not by mileage. If the oil is dark brown and no longer translucent, then it needs changing. Has to do with the condition of the engine and driving habits, you might be able to many more miles than the norm, just as well as you may have to change it more often than the recommended 3000k. My drag car can turn oil black just idling for a minute LoL, but thats for other reasons...I had a Civic with worn piston rings and I had to change the oil after like every 1000-1500 miles because it was burning.
Old 12-07-12, 04:01 PM
sam12345
sam12345's Avatar
Every other year as long as you heat it up. So if all your trips are real short, less than 5 miles then when you get gas get it at a far away place 8 to 10 miles of highway driving because if not condensation will eventually add water to your oil and getting it warm helps evaporate the condensation.
Old 12-07-12, 04:12 PM
LexXxtacy
LexXxtacy's Avatar
everyones different. Personally I always change mine before winter and then again during spring but like jokster said it depends on engine conditiona nd driving habits n such..
Old 12-07-12, 07:24 PM
LebShowoff
LebShowoff's Avatar
You should change your oil every 3 months if you're only doing 5,000 miles a year. Stop and go traffic and short distance driving is worse than highway driving. I believe Penzoil makes a type of oil strictly for vehicles that see a lot of stop and go traffic and short distance driving. I wouldn't go past 3 months on the same oil unless you're doing some highway driving.
Old 12-07-12, 07:38 PM
DosyBoy
DosyBoy's Avatar
When it gets dirty change it, it's as simple as that, your gonna get so many comments on whats the best oil, whats the best intervals, etc etc, dirty..change..done..
Old 12-07-12, 08:56 PM
RXGS
RXGS's Avatar
I feel like i'm the only one whose changing their oil once a month, i need to drive less.
Old 12-07-12, 11:07 PM
pinoiryder
pinoiryder's Avatar
^^^^ What he said..
I change mine every 3500 miles with 5W30 because it is free from the dealer i bought my car from..
Old 12-08-12, 12:01 AM
1sWt2GS
1sWt2GS's Avatar
ive had this happen to my car (only have 70k miles) and drove like 3k miels last year
i had my parents start up my car and drive around the block and still changed it after 6 months.
Old 12-08-12, 12:16 AM
elevate
elevate's Avatar
You work at a Jiffy Lube, don't you...LOL
Old 12-08-12, 10:20 AM
BRAD123
BRAD123's Avatar
I would say twice a year if your only doing 5K a year.
Old 12-08-12, 10:55 AM
drillus
drillus's Avatar
Once a year
I use 0w40
Old 12-08-12, 12:30 PM
bondye
bondye's Avatar
i am changing mine on 10k km, which is about 6k miles but i think in US recomendation is 3k miles due to sulphur in the gasoline.
Old 12-08-12, 08:55 PM
Badxdawgx
Badxdawgx's Avatar
I do mine around 6k ~ 7k ish
Old 12-09-12, 11:19 AM
LebShowoff
LebShowoff's Avatar
I work at Lexus of Kendall... lol. You can change the oil on your car whenever you want, i choose to do it every 3k miles or every 3 months, whichever comes fist, even if it is synthetic. Nice try though.
Quick Reply: How often should I change the 5W-30 synthetic oil if I drive 5K miles a year?
