Suspension Parts
Suspension Parts
Thinking of replacing ball joints and bushings on a 98 GS400. car wonder a little bit sometime like driving in the rain but the road is dry. sometimes in low speed braking, the steering wheel would turn it self to the right or left. also 70+ steering wheel shake. from reading the GS section, these parts need to be replace or am I wrong?
just wanted to make sure
here is the screen shoot from sewell lexus. are these the correct parts and price?
tie rods should be replace too?
any other parts should be replace?
other than sewell any other place i should consider to shop?
thx in advance
thx in advance
Here's all that I SUGGEST when running slammed for a full suspension overhaul. Do all of this and you will not be dissatisfied with your choice to drop so much money on your suspension.
-: Moog LBJ's
-: Moog Outer Tie Rods
-: New Steering Rack Bushings
-: TRD Sway Bars
-: FIGS Front Sway Bar Endlinks
-: FIGS Rear Sway Bar Endlinks
-: FIGS Front RCA's
-: Battle Version/FIGS Rear Toe Links
-: Battle Version/FIGS Rear Traction Links
-: Battle Version/FIGS Rear Adjustable Rear Lower Control Arm
https://www.rockauto.com/ -- Moog Parts
http://lexus.sewellparts.com/parts-c...S300-1998.html -- Steering Rack Bushings & Sway Bars. Sign up as a CL member for a nice discount.
http://www.shopfigs.com/v1/ -- FIGS Adjustable Links
http://battleversion.com/ -- Battle Version Adjustable Links
-: Moog LBJ's
-: TRD Sway Bars
-: FIGS Front RCA's
found this on another thread when i was looking to buy suspension parts. i hope it helps.
It all depends on what you're going to be doing with your car to be honest, unless you're gonna drop your car half of that stuff isn't needed. If you're just going to be driving stock but want to replace some things for piece of mind and want to increase handling I would recommend doing these..
-: Moog LBJ
-: Steering Rack Bushings (Sewell)
-: FIGS Front/Rear Sway Endlinks
-: TRD Sways (Sewell)
first off, thx luxurygs3. bought and put on the moog lower ball joint and outer tie rod. what a difference. steering feels more solid, stiffer, doesnt sway like it use to. is alignment needed after replacing them? going to install caster arm bushing and few other bushing, will i need alignment again after the bushing install? thx
