how do i disarm the air bags?
okay so i need to disarm the airbags in my 01 gs300...is the a fuse or plug that i can just unplug and all the air bags will disarm? or will i have to go to each one and un plug them?thanks...
iModerate
Set key to LOCK position. Disconnect the NEGATIVE battery cable and shield/isolate it - make sure it will not find a way to make contact with the battery. Wait at least 90 seconds before starting to work with the airbag components.
When you are done hook the negative battery back up. I would make sure no one is in front of the airbags but that is just me.
iModerate
As already asked what are you planning on doing that requires the airbags be disarmed?
hsmac
RX - 1st Gen (1999-2003)
05-23-16 08:50 PM
MongooseGA
SC- 1st Gen (1992-2000)
04-13-09 11:55 PM
