Ho ho ho! Verily my steed overheateth
seriously drving home.from work the gs overheated it was.driving.fine an.all.of a sudden i saw the dials an it was overheating all the way stopped the car cooled down a little.an managed to.drive it.to my mechanics shop but he is on vacation comes back.tomorrow..... for no reason nothing just overheated seriously worst time ever
Posted from ClubLexus.com App for Android
This happened to me a couple months ago while waiting in line at mcdonalds. It turned out to be the coolant temp sensor that tells the fans to turn on. I fixed it the next day, part is available at autozone and it's easy to replace. Turn the car on and wait for it to get up to operating temp. Then give it some gas and idle it higher, if the temp starts going up and your fans don't kick on, that's your problem. It's located on the driver's side at the bottom of the radiator by the drain ****. Relays and fuses can also cause the fans to not kick on, but that wasn't my problem.
Dang where did you buy your car from? The junk yard? Every since you got the car and posted on CL, it was nothing but problems. Sorry but you probably got a lemon or got fooled into believing it was in outstanding shape. I'd definitely check the fuse or what he stated above. Good luck to you bro. Hope you get all that kinked worked out
I know its the last thing I fix on it love everything about the car bout its a little outdated hehe honestly just alternator went bad an dealer covered that for me an water leaked yesterday in but not today so just the two bad things I just always have questions
Messatsu
13
05-14-15 07:04 PM
