Catalytic converter
My first question would be does Ohio have emissions check or if like my area of Virginia that has none. My Rav 4 has codes 420 and 430, but runs fine and gas mileage is same. I plan to keep running until I have real problems whenever that might be.
I have a 2002 lexus is300. The cel came on with a 430 code saying it was the Bank 2 converter. If it turns out that my cat has to be replaced Im wanting to know has anyone used an aftermarket catalytic converter such as Magnaflow and has it worked for you over a period of time? I was told by the smog tech that the cat replacement must be a OEM lexus cat or the CEL will eventually come back on in a short period of time. As most of you know Lexus OEM cats are very expensive and im hoping a good aftermarket will do the job.
ShiftyD2k
Performance & Maintenance
06-11-10 10:02 PM
KingNasGS4
10-29-09 11:04 PM
kazam
01-23-07 03:36 PM
