First diff fluid change after 108K miles (nasty drain plug pic!)
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
First off, I'm not positive the diff fluid hasn't been changed in 108K miles. But I just bought this thing and the previous owner included pretty detailed records; pretty much everything except a diff fluid change. Judging by what I see, it surely was not done recently.
Anyway, as you may know the drain and fill plug bolts are magnetic on most vehicles. Here's the drain plug just after I removed it. Nasty!
![](http://i118.photobucket.com/albums/o107/cdaviesaz/lexdrainplug_zpsfb03c5ea.jpg)
Remember, if you're going to do this, always remove the fill plug first. I soaked mine with PB Blaster and gave it a couple good whacks with a hammer and they both busted free.
164K?! Whoa! It's way easier than an oil change. Just go for it.
One thing I don't see anyone mention on searches is to replace the crush washers for the fill and drain plugs. They are there and they are NOT a standard size. FYI
I didn't replace mine, but I should have.
I used Amsoil 500K mi 75W-90 because I happen to have some (and Amsoil rocks!). I had to supplement with some off-the-shelf 75W-90 full synthetic because I only had a qt of Amsoil and my diff took about 1.6qts before it started leaking out the fill hole (that's when you know it's full).
Hope that helps!
Hope that helps!
Haven't had a chance yet funny enough. But later today I will. The good news is that I had no gear whine or clunking or anything so the change should be minimal.
But yeah make sure you report back and let us know how she feels.
