How to remove rear diff cover
Old 12-30-12, 05:11 PM
Grease
Grease's Avatar
Default How to remove rear diff cover
I accidentally push in a 3 inces 3/8 tube inside.diff while refilling fluid. I need to open up diff.however, i cannot see or easily reach the top bolts so maybe some one here can help me with the procedure on how to remove the cover..
Old 12-30-12, 09:27 PM
sakataj
sakataj's Avatar
??? it just unscrews..... i have taken mine off while it was on the car before, im fixing to take my old one off and replace it with my P.C. one (yes i cleaned off the PC on the inside of that, dunno why he did that)
Old 12-31-12, 04:04 PM
Grease
Grease's Avatar
So I'm assuming you meant I only need to unscrew these two hex bolts in red shown in the attached picture and then proceed with the 6 or 8 bolts (in blue). And reinstalling will be just doing the reverse. I hope I have not damage anything yet as I drove it this morning with the plastic tube inside because I thought reinstalling will require moving or pushing the entire case forward which I think will be so difficult. I lost hope I guess and just hoped gears will cut into pieces and flush out when I drain the fluid again.
BTW. Nice color. I might do the same in red. Also will take picture of this process so I can share it to beginners like me.
Old 12-31-12, 04:40 PM
porn-adkt
porn-adkt's Avatar
support diff via jack unless your gonna bench press it down (not sure if your using a lift or driveway)
remove bolts from ears
remove 3 hex bolts you circled.
remove right and left sub frame brace, if you have never removed them (bolts) you will need to heat them other wise get ready to snap them.
once all done, lower diff via jack.
Access bolts to cover. use chisel tool to break seal.
Old 12-31-12, 06:52 PM
Grease
Grease's Avatar
I did not see anyone commenting or warning me that this is a difficult process so I'm assuming I can do this myself (no assistant) by just following the steps provided by ****-akdt. I'm going to do this with jack in my garage.
Questions:
1. What bolts from ears. Where is that in the picture?
2. Where is the right and left subframe brace? Could you help me locate that from the attached picture. Is this in one of the picture provided by sakataj. Which one?
3. Can I first loosen the 8 bolts while the 3 hex blts are attached (not lo0se)? So the case does not move when turning the 8 bolts out with pressure.
4. Do you guys think I should do this procedure? Or just leave that 5/8 dia / 3 inches plastic tube inside case and hope that eventually it will be chewed to pieces and come out in my next drain. Do you have thought that this can damage the components inside as it floats arounbd with the oil?
5. I'll be more fearless if I can see the procedure on video. Anyone seen one?
I really appreaciate your input here guys. And I really wish you can provide more infomation or tips, right tools, and warnings based on your experience as I'd like to first prep things I would need before I begin some work. And first perform the procedure mentally with your instructions.
Thanks.
Old 01-01-13, 10:56 AM
JeffTsai
JeffTsai's Avatar
Bolts from ears is referring to the front 2 big bolts holding the diff in the car. There are a total of 5 bolts holding the diff into the car. Two big ones on the side towards the front of the car. They look more like small arms sticking out of the diff. Not really ears, but thats what some refer to them. Then theres the 3 big hex bolts on the diff cover itself. Make sure the diff is supported by a jack or something first, then once all of those bolts are out you can lower the diff. Also, you pull the eight 10mm hex bolts attaching the axles to the diff on each side first. Do that before anything else.
PS: I would highly suggest against leaving that rubber hose in there. Who know what that rubber will do when grinding around inside the gears. You could risk it, but you will be stranded on the side of the road if it fails. Then not to mention you will have to buy another diff and do this procedure anyways.
I was in the process of making a differential removal and installation video. Never finished it though lol.
Old 01-02-13, 03:35 AM
Grease
Grease's Avatar
Thank you. I'll find all the bolts you mentioned this weekend and see if I can complete the procedure myself. Measure the bolt sizes and prep the right tools, extensions. But if you still have the tools in mind. Please share.
Also, I'm a little worried about below instruction from Jeff. It seems I have to detach/separate the left and right axle and not sure what to expect when reinstalling it back. Is there anything I should know when reinstalling the left and right axle?
Jeff's instruction.
"Also, you pull the eight 10mm hex bolts attaching the axles to the diff on each side first. Do that before anything else."
I hope this is purely plug and play kind of thing and nothing will be out of specs once all is reinstalled.
And I'm assuming reinstalling will just be the reverse.
I don't know the torque specs so hopefully someone can share that information to me as well.
Again, Thanks to all for the input.
Old 01-08-13, 06:38 PM
Grease
Grease's Avatar
Gave the work to a mechanic who charged me 100.00. And I was happy about that decision bec I think I could have either hurt myself or break something working in tight space.. You need a differential Jack for this task and not just the regular jack. I'm having problem uploading pictures so I'll just try tomorrow or the next time I logon.
Old 01-08-13, 07:03 PM
Grease
Grease's Avatar
having problem posting pictures, will try tomorrow or the next time i logon. I have it done by a mechanic. will tell more with the pictures.
Old 01-08-13, 07:04 PM
porn-adkt
porn-adkt's Avatar
Not entirely accurate..
You need a trans/diff jack if your working from a lift.
A regular jack will do fine working from the ground.
Old 01-15-13, 01:33 AM
Grease
Grease's Avatar
Uploaded the pictures just to give others an idea. Here's the first 5 pictures.
Attached Thumbnails How to remove rear diff cover-photo.jpg   How to remove rear diff cover-photo2.jpg   How to remove rear diff cover-photo3.jpg   How to remove rear diff cover-photo4.jpg   How to remove rear diff cover-photo5.jpg
Old 01-15-13, 01:39 AM
Grease
Grease's Avatar
Pictures are not in the order the parts were taken off. Just follow the instruction described by other members in this thread.
Attached Thumbnails How to remove rear diff cover-photo6.jpg   How to remove rear diff cover-photo7.jpg
Old 05-03-18, 12:42 PM
toneekay
toneekay's Avatar
Bumping this thread... Would anyone happen to know the rear diff cover bolts torque specs?
tsxnbp
06-19-15 04:25 PM
Lexus97ES
23
10-31-12 11:36 AM
rrolff
GX - 1st Gen (2003-2009)
12-04-09 02:19 PM
dixiebuyer
10-27-09 07:01 PM
HKGS300
10-21-03 03:58 PM
Quick Reply: How to remove rear diff cover
