Gs300 Not starting
Did you ever figure out what the cause was? I have the same issue (mine sounds exactly the same) on my 03 GS300. I checked the fuel pump to hear if it was priming, fuse wasn't blown, and the relay seemed to click (by checked, i mean to the best of my knowledge. i'm not a mechanic).
I even cleaned the MAF.
Want to try to fix myself before having to bring it into a shop.
car was not starting and i replace the fuel filter fuel pump and fuel pressure regulator. now my car sounds exactly like this. did you ever figure it out. or any one else have this issue
It has a nasty crank. Chared the battery and adjusted the terminals and still nothing
video below.
http://www.youtube.com/watch?v=H7vjUdDSDlE
video below.
This happened to my car
I readjust the timing belt and goes fine
Regards
Was your car starting before the fuel pump, mine wasnt. After installing the pump i get this sounds.I redid everything still nothing. I don't hear the pump turning on. But had fuel coming out when I took it apart the second time. Keep me updated if u find a fix
Yes my car actually died on the freeway like it ran out of gas no problems before then
[QUOTE=freshmoney;8766319]What is the best and fast way to check the timing belt on a 2jz..[/
You can check it by the marks ( points ) on the pullys (cam shafts and crank shafts )
I will try to find a video to you explains how to check the timming belt adjusting
Regards
Regards
