Speed sensor location
my 02 GS is throwing a po715 code which is Transmission/turbine circuit malfunction. Transmission has been shifting kinda funny and i hear that it is a sensor that is connected on or near the Tranny. Has anyone ever replaced thier Speed sensor before? is it fairly easy? Where is the exact location?
Jman89 (09-02-23)
Thank u so much for this pic. now i know exactly where to look. from the looks of this, it seems fairly easy to replace.
Was looking for the #1 for about 30 minutes and finally came back to this forum and did a search for all posts about the tranny speed sensor. Just wanted to say thanks, 99 GS3, for the photo! Helped a lot. Unfortunately even after changing #1 speed sensor still have same issue. Guess I'll try to clean and re-install sensor #2 and see if that does anything. Sure ain't easy to get to #1, great design, Toyota! ![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
I just tightened as much as I could, maybe that's the issue? It's so difficult to get a wrench on it, socket was impossible. Let us know if you get it sorted out. I could get the O/D light to stop flashing but it's not going into overdrive. I only bought one sensor so I'm planning to take out #2, clean it and put it back again and see if that does anything cause I read somewhere that might could work.
Not sure if you're having the same issue as mine (O/D light flashing, not going into overdrive, cruise control not working) but found a solution on a Soarer forum that I'm going to try: http://www.supraforums.com/forum/sho...t-does-it-mean.
You may want to check out this thread....it was what was wrong with my vehicle, the sensors weren't the issue: [URL="https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/656360-all-my-crazy-lexus-issues-solved-ecu-leaking-capacitor.html"]https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/656360-all-my-crazy-lexus-issues-solved-ecu-leaking-capacitor.html[/URL
UNDER the car. What kind of issues are you having?
My speedometer and mileage reader isn't working
