Paint like this?
Old 01-04-03, 04:40 AM
DuB
DuB's Avatar
I'm not totally done yet though. I haven't sealed the lights yet and I need to clean the glass off
Old 01-04-03, 06:12 PM
ceoart
ceoart's Avatar
Cool
You will need night vision goggles, because your lights are going to be much dimmer after you do this. :eek:
Old 01-04-03, 07:11 PM
Jmai22
Jmai22's Avatar
what the heck are you talkin about?? he didn't even paint the actual reflector part. all he painted was the trim. so it won't effect the light output at all. it will decrease glare and INCREASE your cutoff line though. thats a good thing
btw, that looks really really good. i'm planning to do the same for my car. is that flat black?? or is it chromy. kinda hard to tell from the picture. also what was yuor procedure on painting it. did you sand off all the old stuff first, did you use primer?? thanks
Old 01-05-03, 02:54 AM
DuB
DuB's Avatar
Thanks for the compliments Jmai.
Yeah, I only painted the trim parts. I studied the beam pattern from my HIDs and the flat bottom part actually caused a little more glare, so painting it black will help w/ the cutoff pattern and glare as you said.
The paint I used was Rustoleum Satin Black so it's like a semi-gloss.
I just primered the chrome, and then sprayed the paint on. I'm not sure how it's going to hold up though. I'm a little worried the heat might make it crack or something.
Old 01-05-03, 02:57 AM
Jmai22
Jmai22's Avatar
where can i get that type of stuff?? i guess semi glass is better than chrome. i kinda got glare after i put in my HID's
Old 01-06-03, 01:00 AM
DuB
DuB's Avatar
My favorite place, Home Depot
They also have normal Rustoleum semi-gloss black, but the Home Depot I went to that time didn't have it, so I got the satin black and a metallic black. The metallic black had a silver flake in it though so I went w/ satin black.
Old 01-16-03, 02:58 AM
legendary
legendary's Avatar
I agree, the paint from home depot...black satin works perfect.
Also, what works best IMO is putting them in the preheated oven, and 'baking them open' at 250 for 5-10 minutes, tops.
I took the plunge on that last year...the effect is sinister imo...I like it.
Also, you don't have to sand/primer it, just two good coats will do.
before:
after:
more pictures
Old 01-16-03, 03:02 AM
Jmai22
Jmai22's Avatar
nice legend.
you don't have to sand or prime it?? won't it just run off then??
Old 01-16-03, 05:44 AM
legendary
legendary's Avatar
Originally posted by Jmai22
nice legend.
thank you..my experience with it required no sanding or priming. If you use light even strokes, it should come out just fine
keyur246
04-19-13 12:34 PM
Grazy
IS - 1st Gen (2001-2005)
08-27-09 10:00 PM
arch95leo
03-30-09 01:49 PM
Starbaii
02-26-08 11:37 PM
SPEED&ECO.
01-03-06 08:24 AM
Quick Reply: Paint like this?
