Driver side climate control always cold.
My GS's driver's side temperature control isn't working.. I replaced the servo on the drivers side but the problem persists. I can are the servo operating and moving the levers on the HVAC box but it still blows colds. Has anybody else run into this problem??
i have a similar issue.
on auto or on manual. driver side gets cold at a specific point when the cabin temp sensor sees it is too "hot".
example: auto control selected to 77. out side temp 40. about 20 minutes in the driver vent is blowing many degrees colder than the pass side. i activate duel mode, and increase driver side to 79. driver blows warm again. pain in the ***, but that is my solution until l can figure out the problem part. i think the driver side cabin sensor is faulty.
Anyone have a service manual for the GS a/c computer self diagnostics?
for instance in the Supra press and old a few buttons and it will blink back at you a code to point in the right direction....
thanks!
thanks!
I had the exact same problem. Replaced drivers servo - still cold.
Had Lexus do a power flush of coolant and heater core. Problem solved! I now have heat both sides.
God luck.
God luck.
allenclan1
10-30-20 12:46 PM
