Is there a mod that reverses the vsc? In other words the vsc is always off and when you press the button it turns it on. I get tired of pressing the vsc off every time I drive, and with it on driving is no fun.
Gonna jump in on this one. When I push my VSC button on the console, I get a light that says VSC "Off." So, pushing the button removes VSC and I can spin the wheels like crazy in the snow and ice around here. When I push the button again the light goes out and VSC is back "On." Then when I stomp the gas I get the traction control kicking in, or I if I hit the gas on a snowy corner I get the warning beeps and the ABS stops the tail from kicking out. So, on my car, VSC is always "On" unless I hit the button. Just wanted to make sure I understood the question. Maybe it's in those settings the dealer can customize for you?
Right. I want it opposite. Always off and it turns on when I hit the button. The dealer will never have it be off as the default mode, USA has too many lawyers for that.
what if you popped the switch out and just reversed the wires
Don't think that will work I think when you hit the switch you are sending a signal to a computer. It would probably involve a electronic circuit that sends the signal at start up
