No Codes No VSC/ABS
No Codes No VSC/ABS
So I knew my VSC/ABS lights weren't coming on and I found out the bulbs were not there. I also assume these bulbs connect to something, but where the bulbs would be, theres just a socket but not a wire or some sort to connect to. Assuming the VSC/ABS doesnt work, being the reason the previous owner to pull the bulbs, wouldnt the malfunctioning VSC/ABS throw a code? Remembering when I took it to get the CEL scanned, 1 code only showed up which was an EVAP system code. This is boggeling me, no codes but the bulbs pulled out. Any imputs?
