2000 gs300 brake issues in ny
My 2000 GS300 has been having brake issues. The issue is whenever you apply the brakes, the first press of the pedal is soft and goes all the way down close to the floor before you feel the brakes being applied, however, if you quickly release the pedal and depress it again the pedal is firm and you feel the brake being applied immidiatley as expected.
I have bled the brakes several times and used several different methods and the problem is still there. I heard there is a way to use a computer to bleed the abs and master cylinder. Does any one know where in NY city I can get this done other than at the Dealer?
