Waterless coolant
Old 01-23-13 | 09:48 PM
sam12345's Avatar
sam12345
Default Waterless coolant
Anybody try waterless coolant? What has been your experience?
http://www.evanscoolants.com/index.html
http://www.evanscooling.com/
Old 01-23-13 | 10:31 PM
porn-adkt's Avatar
porn-adkt
why do you need this?
Run Toyota red 50/50
END OF THREAD....
Old 01-23-13 | 11:33 PM
sam12345's Avatar
sam12345
Obviously you did not pay attention. So buzz off. If you have not used it I do not want your opinion nor your sarcasm. Notice my question
Old 01-24-13 | 06:00 AM
porn-adkt's Avatar
porn-adkt
I use waterless everything..I use waterless carwash, waterless soup, waterless showers..its awesome.
Is your engine experiencing corrosion due to the use of Toyota Red, which is what you should be using..?
Notice my question
Old 01-24-13 | 06:20 AM
sam12345's Avatar
sam12345
My post is for people who have actually used the waterless coolant not to argue about Toyota coolant. Since you obviously have not buzz off.
Old 01-24-13 | 12:06 PM
818GS's Avatar
818GS
I have not used waterless coolant but I've read that if your not in freezing climates using mostly water is better than coolant.
Old 01-24-13 | 04:59 PM
sam12345's Avatar
sam12345
That's true as far as heat transfer but not as far as corrosion and lubrication. Not sure how this stuff is in heat transfer but it seems a lot of people in Saudi Arabia use it and like it. They have 120F temperatures over there.
Old 01-24-13 | 05:55 PM
VWTim's Avatar
VWTim
I haven't ran it, but I did research it back when I was running my race car.
Heat transfer is supposed to be better than water based coolants at the time. Only issue is flammability, it can burn.
Old 01-24-13 | 11:17 PM
sam12345's Avatar
sam12345
Thanks for the heads up. I found this when I googled is Evans waterless coolant flamable.
http://www.ffcars.com/forums/17-fact...s-coolant.html
Old 01-25-13 | 10:57 PM
sam12345's Avatar
sam12345
Apparently 50/50 antifreeze has a much lower flash point
http://www.k-chem.net/Antifreeze%20Fires.pdf
pinoiryder
11-11-12 05:44 PM
Pescao
RX - 1st Gen (1999-2003)
15
12-24-09 02:06 PM
rtk7
01-12-08 03:20 AM
Philly RX
01-08-06 07:33 AM
Benjamin T
Maintenance
16
09-09-05 01:54 PM
