Does the 98-05 GS300/400/430 have "Subframe Bolts" ?
If so, where in the world are they, and can loose subframe bolts lead to clunking over bumps?
Anyone have a pic of these mysterious subframe bolts?
Thanks,
Luke
Thanks,
Luke
Not sure if this is the subframe brace ur talking about... I put these on when i lowered my car to help with preventing rear wheel hop. I remember the bolts that hold these in place look just like the 10mm bolts on the headlights just slightly longer.
Old brace with the two bolts
Hi Mike,
I actually have no clue what I am talking about, lol. I've just seen several threads over the past few weeks that said if your suspension is clunking over bumps, check the "subframe bolts"
I don't know what they, where they are, or if there are front/rear ones?
I'm hoping someone can shed some light on this.
I will check the two bolts you are showing for tightness however.
Sam, are you saying the the subframe connects the engine to the chassis (in the Mustang world this would be called a K-member - it also has 4 bolts).
If someone can show a pic of this, that would be awesome.
Mike, are you saying that you have a 2GS without suspension problems???
Third picture on post 29
https://www.clublexus.com/forums/gs-...attempt-2.html
You can see it is got a gap and the nut was already removed
