2001 gs300 - 20INCH RIMS
20 inch will fit, atleast mine do, ive heared up to 24 inchs could fit but there will be rubbing, i have stock suspension , so if your vehicle is lowered then guranteed it could rub. im running 225/45/20 front 245/45/20 in the rear
OFFSETS OFFSETS OFFSETS
OP:
Measure from your hub to the spindle, then measure from the back of the wheel (where it mounts) to back lip. If the wheel number is larger, its gonna rub, simple as that... Do the same for the front but measure from the inside of the center of the wheel (where you mount the wheel) to the outer lip/face of rim. And again, from the hub to lip of your fender.
