Gs300 2001
Old 02-01-13, 01:24 AM
dearharris
dearharris's Avatar
Default Gs300 2001
Hey Guys.. i have few problems with my car.
First i have problem in Alternator. i changed alternator 4 months ago and till now i changed 3 times and mechanic said u cant change now in warranty because you have problem in your car that is why your alternator not work. he said i have problem that my car has HID lights and Sound System and Heater that take too much watts and your alternator cant handle this.. can you tell me what should i do ? please..
Second in problem in my car is when i am driving more than 50 mph and i push brake my car out of control and i feel like car Tyre flat or something.. some people said to me you have to change brake pads and rottors and some said i have problem with balancing you check you wheel balancing.. can anyone tell me about this please.. thank you
Old 02-01-13, 08:25 AM
BlKTC
BlKTC's Avatar
1. if you changed your alternator, then your alternator should be fine.. The problem will have to start somewhere else.. Get a voltameter and check to see if you have the proper wattage on your battery.. (car off = 12V, car on = 13 or 14V)
2. The vibrations in your steering wheel are solely caused from uneven rotors. If your wheel was unbalanced, you would feel vibrations regardless of stepping on the brake. (Rotors can be resurfaced, or you can just buy new ones)
ps: if you don't have a voltameter, you can get it checked at pep boys or something, for free.
Old 02-05-13, 05:12 PM
dearharris
dearharris's Avatar
Thank you for help .. i will go to any mechanic.. actually am scared to go to the mechanic becoz they charge too much money and i dont know how they works..
Old 02-06-13, 12:50 AM
BlKTC
BlKTC's Avatar
yeah just go to a pep boys near you or something.. they would be able to help you out free of charge.
Old 02-06-13, 02:20 PM
aneidiaz
aneidiaz's Avatar
Good luck with your issues my friend. Read around once you pinpointed what you think it may be. This site really helps save big $$$. Check your battery for voltage reading like others said. Also, vibrations can be a multitude of things. Brake pads, rotors, tires, possible damaged rims, suspension + alignment issues. Check em all 1 by 1., If you don't have the knowledge it skills to do so, just take it to a mechanic. Firestones around my way are really helpful.
Old 02-06-13, 02:45 PM
Advil4u
Advil4u's Avatar
1) why do you say your alternator is bad. please specify the problem you are having that leads you to belive its the alternator
2) most of the time when u have a bent wheel or unbalanced wheel or even a warpped tire your car/steering wheel will schake at diffrent speeds if ur problem is just when you step on the brake sounds to like its urs rotors wich are warpped u can get those resufaced for cheap if u have enough meet on them or just replace them
rx04Lexus
04-30-10 02:30 PM
lakemist
GX - 1st Gen (2003-2009)
08-05-09 11:11 PM
lawgs300
04-19-01 06:35 PM
Quick Reply: Gs300 2001
