DIY: Paint Caliper for 2GS
Old 02-01-13, 11:44 PM
1sWt2GS
1sWt2GS's Avatar
Default DIY: Paint Caliper for 2GS
A few members on the forums have known that I've been wanting to paint my calipers for a while now, but haven't got around to it.
Well I'm currently sitting here waiting for the paint to dry so thought I would make a write up for those who want to do this.
Its not a complete DIY but should have many pictures for those who need it.
I DO NOT HAVE ANY RESPONSIBILITY FOR THOSE WHO MESS UP! PLEASE BE CAREFUL WHEN WORKING UNDER / NEAR YOUR CAR.
*All pictures are taken on the passenger front side
Tools needed:
-Masking tape
- Plastic paint sheet
- Newspapers
- Wire brush
- Small screwdriver
- Low profile jack + jack stands + scizzor jack (my cars too low
- Tools to open lug nuts + open lock
- Caliper paint
- Brake cleaner
- Warm water + soap solution
- rags to wipe down brakes
- lexus decals
left to right
primer, clear coat, caliper paint, brake cleaner
i skipped the jacking up part (use the frame) and make sure to use jackstands, im doing 1 side at a time because i only have two jackstands.
heres how it looks jacked up
After that, I layed down newspaper on the floor, sprayed brake cleaner and used a toothbrush / metal brush to clean the calipers wipe it off
After, use a toothbrush along with the warm soap + water solution and wipe it off once again
Let it dry ~30 mins
Grab masking tape and mask off anything that you aren't painting. I myself masked off metal tabs, rubber pieces, and the brake pads.
What I did with the plastic bag is draped it over everything then teared it to exactly fit just the caliper
Grab the primer can and shake well. Hold ~8-12 inches away and apply 1 coat of primer. Between sprays, turn can upside down and spray alittle to clear the valve.
Wait 15 minutes, and apply a second coat
Heres how it looks with two coats of primer
Heres the first coat of black. I applied coats total, waiting 10 minutes between each coat.
second coat of black
decal installed + 1 layer clear coat
near the E, the sticker took off part of the paint already due to me being stupid and putting it on and taking it off . make sure you only put it on ONCE the first time!
Old 02-01-13, 11:45 PM
1sWt2GS
1sWt2GS's Avatar
saved for final pictures, ill continue updating this as I go (waiting for primer to dry)
Old 02-02-13, 12:48 AM
armanitran
armanitran's Avatar
Why not disconnect the caliper and paint the whole thing evenly?
Old 02-02-13, 01:08 AM
AVSRacing
AVSRacing's Avatar
do you really need the primer? I was only gonna do the paint colour. I was reading up that the engine enamel clear will turn yellow so I've decided not to use it.
Old 02-02-13, 01:11 AM
Dranom
Dranom's Avatar
I need to paint mine too
Old 02-02-13, 01:57 AM
1sWt2GS
1sWt2GS's Avatar
i feel like its not needed or i could just be lazy
ive read that you dont really need the primer, but the can was only 2 bucks, so why not. i mainly used it just so the paint would stick better and so it had a base coat.
the engine clear enamel is the thing that holds down the decals so i definitely need it, also gives it a gloss look. haven't heard anything about it turning yellow, but then again im painting the brakes black so it wouldn't really affect it.
do it! its super easy and cheap. just make sure you have something to pass your time, because theres more downtime than acutally working.
Old 02-02-13, 03:23 AM
Acer
Acer's Avatar
I did it exactly the same.I might do it again but this time I'll get it powder coated with upgraded calipers.
Old 02-02-13, 03:35 AM
1sWt2GS
1sWt2GS's Avatar
on the driver side, ill definitely perfect the technique.
the decal is kind of old (left it sitting a long time) so a litle of the paint came off with it on the passenger side! im so upset! but then again, no1 is gonna stare at it
it looks a lot better in person than that picture with the decal installed in the DIY
Old 02-02-13, 03:41 AM
Sevenevez
Sevenevez's Avatar
yet another great DIY. Good mod for those that can't afford BBK's. i like the decal was the icing on the cake also.
Old 02-02-13, 08:55 AM
porn-adkt
porn-adkt's Avatar
Old 02-02-13, 11:18 AM
DosyBoy
DosyBoy's Avatar
Looks great I used g2, theirs no need to take the caliper off
Old 02-02-13, 02:37 PM
armanitran
armanitran's Avatar
Must be my OCD
Can't wait for the finished pictures!
Old 02-02-13, 02:41 PM
DosyBoy
DosyBoy's Avatar
Must be my OCD
Ha ha different paint strokes for different folks!
Old 02-03-13, 12:11 AM
818GS
818GS's Avatar
you should of taken your calipers off and when I installed my decals i taped it on and went for a small drive until the caipers got hot and pealed the back of the decals off and no clear coat. its been fine ever since. and you only need the paint, no clear or primer because the paint gets baked onto the caliper
Old 02-03-13, 05:34 AM
SaiyanGS3
SaiyanGS3's Avatar
Where is your sand paper? That's what really make it stick. I would recommend anyone who does this to use sandpaper first then a, b, c....and clear coat is needed to seal the decal and protect it from road debris.
Quick Reply: DIY: Paint Caliper for 2GS
