GS400 Weird Noise Coming from Steering Column
I have a 2000 GS 400 and it's run perfectly without any problems for years, however, recently, there has been a screeching noise which sounds like it's coming from behind the steering wheel, but after listening a little closer it may be coming from around the break pedal area. At first it was just when I started the car and it was cold outside, but now it's happening every 2 minutes. I'm unsure if it's related to an ABS brake issue or something else. At any rate, I attached a 10sec. clip of the noise...if anyone has had this before or knows what it is, any help would be greatly appreciated.
I checked the PS and brake fluid and both are good. I've been able to figure out the noise happens after I fully press on the brake pedal and then 2 seconds after the noise happens. I also had the beeping sound and the VCS and brake light come one a few times but that hasn't happened in a while. How much did it cost to have the BMC/Booster replaced.
Thanks again for all the help.
http://car-part.com/
Yes, I had the ABS Pump Brake Booster Module (Brake Master Cylinder) replaced. That took care of the problem...just an expensive fix ($600-$800 for the part + labor).
islandchip
08-25-08 05:01 PM
