check engine light on....
I had a friend run a codescanner on it and it pulled up p0441, p0446, and p0440, anyone know what this might be? I don't notice a difference in the way it drives. It's been on for about 3 week now with nothing acting weird.
iModerate
I suggest you search the 2GS forum for previous posts and resolutions to these codes. I suggest you search each code one at a time (more results + info) or all three together (less results). These are relatively common codes which many members have been able to isolate and resolve. Let me know if you need assistance with searching the 2GS Forum. I will be happy to help you out.
wow guys, didn't realize I pissed off so many people by asking questions that might have simple answers like it's a common problem of our cars or something is what I was asking. Your right, I should of sat through and searched each code before posting, but thought this might be something that goes wrong that is a part that is common that goes out. I'll do my research on my own next time and never post a question until I spend hours researching threads. I will never try to get a quick answer again. Geesh people!
Ditto, take the engine cover off and inspect all the rubber hoses. I had a few dried cracked and broken hoses. Bought a few feet of vacuum hose from Pepboys and replaced them all. Cleared the codes and haven't seen them since.
Hmmm, interesting, gives me some food for thought. I did replace the motor mounts at 90K, but that was 30K miles ago. I doubt they are shot already, but it's worth a look. I'll check it out - thanks for the thought.
ok, next step will be taking off my engine cover and inspecting the hoses, thanks guys. Probably another dumb question, but what kind of side effects would I have if my motor mounts were failing? COuld this be the reason why my steering wheel vibrates at 70mph, no matter how many times I rotate and balance my tires and have brand new brakes, rotors and pads on?
