Transmission Filter & Gasket?
I'm replacing my transmission pan since the previous owner stripped the bolt. After a recent transmission fluid change, it's doing a slow drip so I figure I might as well replace the pan. After searching, I found out that our cars has a filter inside. Also, that there isn't a gasket of sort but some type of silicon.
I found everything on Sewell, but not the filter nor the silicone. So, do we or do we not have a filter in there? Can someone confirm and tell me what the part number for the filter (if we do have it) and the silicone gasket? Thanks
your a old member....welcome back to the club but please search before posting.
depending on your model i posted the part #/link for them in here
https://www.clublexus.com/forums/per...ting-dial.html
since we're on topic, have you had problems ever since you've adjusted the dial? A guy towards the end stated that his transmission took a dump because of it. Reading that is making me debate whether to do it or not.
I have a slow drip as well and actually doing the job in a day or two.So far i've ordered the filter kit from rockauto.com and bought the FIPG from my local Toyota dealership along with ATF Type T-IV transmission fluid..
Even though I ordered the gasket kit I plan on only using the filter and using the OEM FIPG to seal it back up I also ordered a pack of 10 drain plug gasket from rockauto for like 6 buxs.it took about 5 business days..
lserlohn
RX - 1st Gen (1999-2003)
04-11-12 10:38 PM
m1tk4
05-14-09 07:58 AM
