mounted ps2
mounted ps2
figured out to mount ps2, you use the old mounting bracket from the cd chnager, and i hot glued it on the ps2, you have the bend the mounting bracket on the left of the changer so the ps2 will fit and then the whole unit will fit like a charm in there with the old cd changer mounting brackets
yea no cd changer, i got these in the headrest's, audiovox monitors are prettry good, i got the kenwood touchscreen up front but i havne't made the dask piece yet, will post pictures of dash piece, a lot of people out there looking for dash kits for the gs's, what do you think, put them in myself, first time that i have done this kind of stuff, in a car
the only problem is that you have to take out the ps2 controllers everytime you want to close the glove box, you leave the controllers in the glove box, that is the only drawback, but i believe this is the best place for the ps2, the back armrest would be the same way and the driver wouldnt' be able to access it, so the glove box is the best hidden place, thanks
Northern California Regional Officer
Will the PS2 skip when you hit heavy bumps? I only see people using them while parked, but I want my kid to use it on long trips.
Do you play DVD's or just games? Don't know if games are less affected to skipping, than playing DVD's.
no, i haven't had any problems with it skipping, i play games and dvd's, it works awesome, i am actually surprised that it hasnt' skipped yet due to the amount of bumps that i have hit, it iwll work awesome if you mount it, it's just hard cutting away at the stock plastic in the glove box, thanks
You could close the glove box and still have th PS2 controllers conected just sing it to the side and it be ok, because I also have my PS2 connected in my glove, and move my cd changer to the back. If you mounted your PS2 back more you can close it with the remote still connected.
ps2 pictures done
got the ps2 re mounted so the controllers can be plugged in and the glove box and be closed, it is money like no other, here are the pictures, thanks for the help guys, now dash piece
