Tune up now my check engine and VSC lights are on?
So yesterday I did oil, filter, and spark plugs on my Gs400 everything went pretty much smooth execpt for when I removed the plastic intake housing the farthest vacuum line to the firewall snaped at the little neck peace instead of just vacuum line coming off..When looking at it closely I noticed that at some point it had all ready broke and was on there by some type of glue/silicon.I needed the car for today so I had no choice but to try and fix it temporally.So I fixed it with JB weld and a little plastic tube from the help section at advance auto parts.Came out decent but I had to put it all back together before the JB weld had time to dry because it was getting late and I had to have it for work today..It did sit overnight car was not turned on till this morning for work..Car rides and sounds good but now my check engine light and both of my VSC lights are on..Can it be that maybe that vacuum neck plastic piece I installed didnt seal right? ?? Would that cause the VSC light to turm on?? Thanks guys..
Honestly I think those scanners that advance and auto zone have to cheak codes are a pos they dont really tell you much so I was just seeing if anyone has ever ran into the same problem or what not bc I kinda under stand the check engine light turning on if maybe the JB weld didnt seal completly causing me to have a vacuum leak but both of my VSC lights being on is what im mostly worried about..
A vacuum leak is not going to cause your CEL to come on. At least, not a leak that would be as small as what you're describing.
ECU has codes telling you what it thinks is wrong. Pull codes.
As for the scanners being a POS - I'm not sure how that's possible. It is a device that reads codes on the ECU and tells them to you. Not sure how that can be a POS. It's not like they only tell you half of the codes or something. I use a cheap $20 bluetooth OBD-II dongle and an Android app to pull my codes and it doesn't do it any differently than AutoZone does.
Possibly helpful info: My CEL and both VSC lights were on while I had a bad O2 sensor. But I'm sure all 3 lights come on for a variety of different issues.
Yea ima stop at the advance near me and see what code/s its has.What I ment by pos is that it doesn't realy tell you much I use to work for advance and we did it all the time for the customers but most of the time unless its like a o2 senior it wont really tell you much..
It will give you a place to start, at least. It could be as simple as you accidentally knocked an electrical connector loose. For example, if your EGR VSV came unplugged while changing the plugs your car would run perfectly fine but the emissions alerts would light your dash up like a Christmas tree.
Yea I hear ya thanks bro and all three light actually just turned off.I left work and they turned right on drove to my moms to pick up my little man (15 min drive or so) turned off car.Chilled there for about 20 min got in to head to advance auto parts for a free scan but light never turned on..A little worried about what caused for the light to turn on in the 1st place but I'm glad it's gone.
Dear all i need your help please
i have this crazy check vsc problem on my ls400 2000 model was running all fine past three years i owned and after stopping it some like 6 months the battery died so i replaced it and all a sudden check vsc light comes I tried every method possible battery terminals pulls checked all fuses removed the fuses that reset no use. Am running out of hope now
after restarting the system driving few mins latter this crazy check vsc light poops again and the traction control stops working please all lexus owner help am getting nuts
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
First of all, you are posting this in the wrong section and on an old thread. Start a new post in the LS forum.
You need to scan your car for what code is being set. Either buy or borrow a scanner or take it to someone that can scan your vehicle. Removing the battery and clearing the code will not prevent the code form popping back up if there is a fault somewhere.
akafixture
02-13-20 05:28 PM
conroegs
01-05-10 08:08 PM
