Going from 17x8" to 17x7.5" wheels
Just a heads up, there's a few auctions for the one chrome wheel on ebay now... So either you, or a buyer [if you sell] can score the 'missing' wheel for 100$ish
Really? I've yet to see anything chrome and oem on this forum go for less than 6-700$, otherwise I would've bought a set years ago instead of my aftermarket enkei's.
I'm sure if you look around, you can find a set of oem 17s under $500. Or why not upgrade to some oem 18s. If you're set on going aftermarket, you have to get hub centric rings and even with those you might get vibration. The 7.5 will be fine with 235 tires and yes you should get the +40 offset.
Who cares, im buying the isf gunmetal rims in 17" , im not crazy about big rims and dropping my car, hell no, i like the stock/sporty look without having to sacrifice performance, so im sticking with 17" personally, look great to me, then ill use my stock 17" 5 stars for winter.. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Op check these out
http://www.wheelstiresandmore.com/p-...Fe0WMgodvUcAZw
Op check these out
MilkyTech
RX - 3rd Gen (2010-2015)
15
11-22-16 06:33 AM
rfx45
Wheels, Tires & Brakes Forum
09-04-07 10:33 PM
