1999 GS4 with Nakamichi - intermittent popping/static noise from speakers
Old 02-27-13, 03:59 PM
sivikvtec
sivikvtec's Avatar
Default 1999 GS4 with Nakamichi - intermittent popping/static noise from speakers
My speakers have started making random popping/static noises, it only lasts a few seconds. Sometimes it will do it a couple times "pop-pop-pop". It does it on CD and FM, I have not tried cassette or AM. Has anybody had this happen to them? The audio system is completely stock.
Old 02-28-13, 09:25 AM
wbmx1981
wbmx1981's Avatar
do you loose sound at all?
Old 02-28-13, 10:58 AM
DosyBoy
DosyBoy's Avatar
If you get static through speakers its the internal amp, its shot
Old 02-28-13, 11:11 AM
wbmx1981
wbmx1981's Avatar
I've had two issue with my naka so far and they have both been fixed:
First issue:
I would listen to my music loud then it was crackle and I'd loose sound for a few seconds, I'd have to turn the volume down and just wait. I replaced the amp and that fix that.
Second issue:
The balance on the head unit wasnt working properly. When I turned the **** it would create static and cause certain speakers not to play. I took out the deck to find that the ribbon cable from the headunit to the circuit board was twisted causing it to malfunction. This fixed that problem.
I found a guy selling his LX470 naka amp, and it was a plug and play. Good luck.
Old 06-01-13, 08:56 AM
sivikvtec
sivikvtec's Avatar
I replaced the amp with a used one off ebay for around $115. It appears the problem is solved. Thanks for the help! The amp part number is 86280-30380.
Old 08-20-13, 08:59 AM
anesthesia
anesthesia's Avatar
Does anyone know if the amp. Is part of the speaker as a unit or is something else?
Old 08-20-13, 09:25 AM
wbmx1981
wbmx1981's Avatar
On the GS300 Nakamichi the amp is in the trunk beneath the trunk lining.
jakob27990
02-07-17 10:59 AM
ymirali
09-02-14 05:40 AM
vr4gt
03-03-13 11:07 AM
denverdog
04-06-11 08:54 PM
Blue98Gs3
03-31-04 04:31 PM
Quick Reply: 1999 GS4 with Nakamichi - intermittent popping/static noise from speakers
