Noob Transmission Oil Question
Lexus 01 GS 430 104k on the dash.
When & how long should u change the transmission oil?
What type/kind of transmission oil?
How many bottles of transmission oil?
Have anybody use Lucas b/f for engine & transmission? Good or Bad? #justasking
Thanks
Thanks
Do a drain and fill every 30k miles or so. It will use between 3-4 Qts. Use Toyota T-IV Fluid. No need for any of those additives. Just for piece of mind, I drain and fill mine every year to keep things as fresh as possible. ***Also, no matter how much anybody tries to sell you a "flush" for your tranny, don't do it. Only bad things can happen. Also make sure the level is absolutely perfect after you fill it back up. Our trannys are very sensitive to fluid level.
i do have 2002 gs430 and change trans fluild with every oil change (124k miles on car)
use only toyota t-IV trans fluid
by a lexus manual it takes 1.9 qts to drain and fill gs430 trans
Care to explain how "only bad things can happen" ?
Bad things won't happen unless your transmission has never had its transmission fluid changed and you have 150k miles. That is if you do a flush where they use chemicals to clean the sludge and varnish out. I do the "poor mans flush" as soon as I buy a used car and I have never had an issue. When you use the chemicals that are added there is a possibility that you release so much dirt that it pluggs the filters of the solenoids in the electronic transmission or even plug up oil passages. If this happens then malfunction will occur. So the theory goes.
genji
CT 200h Model (2011-2017)
10-02-23 12:43 PM
cubbieblu7
IS - 1st Gen (2001-2005)
06-19-12 09:12 PM
