New Moog LBJ and Outer Tie Rods - steering won't return to center
I just installed new Moog LBJ's and Outer Tie Rods. I just bought the car and didn't drive it for a month while doing maintenance so I can't remember if the steering wouldn't return before I replaced those parts.
Is this due to just needing an alignment or could I have done something wrong during the install? I searched and found info on the steering pre-tensioner and will try that, and am definitely getting an alignment next week as well. Just wondering if anyone else noticed steering not returning to center after new LBJ.
FYI, it's an 01 GS430 with 45k miles and lowered on L-tuned springs.
I just did all this and more recently. I took it to Firestone for their lifetime alignment and they told me the same thing about my steering not returning to center before the alignment. After completing the alignment, the steering returned to center. So take it to get an alignment and hopefully that fixes your problem. The issue was caused by the outer and inner tie rods I replaced. I did not adjust them accordingly and it screwed up the steering. Good luck.
You just need to align it. When you put the tie rods in, you didnt measure how far the old ones were screwed in. one side is screwed in farther than the other. Alignment shop can take care of that. Or, remove the tie rods, turn the wheel straight THEN install them correctly.
Thanks for the responses.
I marked the lock nut on the outer tie rods and installed the new ones accordingly. I thought they were back to the right spots but maybe the Moog are slightly different than OEM, who knows. The steering wheel is centered and the returning seems a little bit better today, still returns only to 11 or 1 o'clock, never to 12. I'll respond to the thread once the alignment is done.
I did my outer tie rod ends and I have a issue. The passenger side tie rod end seems to be in correct position with the locking bolt. I lined it up with the old one. The drivers side nut ended up all the way to the end and now I can't loosen the tie rod end to adjust it. I have moog tie rod ends do I need to try to take it off or can a alignment shop fix it
shop can do it all.
remember, you can spin the inner tierod freely. Remove the boot, you'll see a 'flat' spot to put a wrench on. The inner tie is just a ball on oneside and threads on the other. This is how they do the alignment at the shops without removing the outer tierod. This is also how you align the steering wheel.
You have to get it aligned no matter what after doing these replacements. Let them worry about it, you'll just do the work that they'll have to redo anyways.
Great way of putting it bro. To the average Joe's who don't know, all they have to worry about is buying the actual parts, getting them installed, and then proceeding to take it for an alignment ASAP after repairs are done. That's it.
NEW PARTS WILL NEVER BE THE SAME AS OLD PARTS, even if you mark your old parts tolerances WILL be different. car just needs an alignment and your set. TYBG for Firestone lifetime alignment as well ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I replaced my ball joints, didnt mess with my tie rods, and steering still got Uncentered.
