What did you do to your GS today?
#1531
$30 for both bushings shipped to me:
http://www.ebay.com/itm/Control-Arm-...tWkTua&vxp=mtr
#1532
I believe there are 60mm and 65mm castor arm bushings depending on VIN production date, but i measured mine to be 60mm, 1998 gs300 and bought 2 bushings, air chissel'd old ones out, pressed in new ones
#1533
I have seen those but no reviews. There seems to be a lot of issues with various caster arm bushings for our cars. The best one is figs but is on the expensive side. The cheaper solutions that has mostly good reviews are bushings from PSB and Roca. Still deciding on which I am going to go with.
#1536
i FINALLY installed this from this thread https://www.clublexus.com/forums/gs-...-movement.html
, i havent driven it on the highway to check on any vibrations yet
#1537
Installed a new headunit last night.
I wanted to stay double din, but didn't want a screen so I'm pretty happy with how it fits and looks.
One question however: everything functions, but I can not get a radio signal. On the back on the radio harness there is one wire left (amp-on), which I'm assuming is remote and needs to be wired to the antenna. I've searched multiple guides and can not find an antenna wire. On 1999 and up it's listed as black w/ red stripe, but on 1998 it says N/A (and I do not have a black/red wire).
Any suggestions?
Thanks!
Any suggestions?
Thanks!
#1538
Do you actually have a power antenna on yours? I have an 03 GS300 and the antenna is built into the windshield. All you should need is the main antenna plug connected. I just did a recent double din install. I added a small amp to power the stock sub, which sounds great! .
#1539
Mine has a power antenna that changes height based on frequency. Because its all integrated with the factory head unit, I can get reception now but the aerial doesn't raise
#1540
#1542
#1543
At the time they had a promotion for a free wired dash cam too.
I am thinking about connecting it to my 01 GS3 ML AMP using the 4.1 RCA preouts, need to find out if the drivers speaker cuts out from the HU, AMP, or speaker first.
#1544
Nice, is that android HU ? what model? form ebay? about to do something same in some time, how is sound quality on that?
#1545
Today I got closer than apparently anyone in living history to solving the case of why the A/C blower doesn't run if the 10A heater fuse is installed.
I'll keep you all hanging until I solve it.
Until then, can somebody please tell me where body ECU #1 is located? I've searched and searched and searched and cannot find the answer.
