What did you do to your GS today?
Old 07-25-17, 07:04 PM
  #2041
GS34B
GS34B's Avatar
Replaced my original stereo with its burnt out LCD screen with a nice used good working one from eBay, and now I can finally see what's on the radio!
Old 07-28-17, 02:38 PM
  #2042
English66
English66's Avatar
KYB Shocks on the front to replace 8 year old ones. New Ball joints and Outer Tie Rods
Old 07-28-17, 02:44 PM
  #2043
Pynoxim
Pynoxim's Avatar
Meh, boosted it, whatever
Old 07-28-17, 05:45 PM
  #2044
962jzsc415
962jzsc415's Avatar
Replaced spark plugs, wires, cap and rotor
Changed rear diff fluid
Change transmission fluid
Found oil in spark plug 5 and 6
Now I got to figure out where it's coming from
On a good note
SHES RUNS GREAT!!!!​​​​​​. Last pic is right before replacement
Old 07-29-17, 12:53 AM
  #2045
Sean628
Sean628's Avatar
easiest tablet install, just sux the aux in doesnt work on the headunit
Old 07-31-17, 12:55 AM
  #2046
Sean628
Sean628's Avatar
replaced the brake master/abs unit yesterday, now I don't have soft pedal anymore just one question, after I correctly bleed the brake and went for a drive, the pump comes on every second time I step on the brake for about 10secs, is that normal? my old one used to come on every 3rd time I step on the brake.
Old 07-31-17, 12:56 PM
  #2047
dreamcar88
dreamcar88's Avatar
took a stab at my driver side ac servo that sounds like poo... I didnt get the servo off all the way but i cleaned some hair off the arm and greased more of it. I dont hear the gerbil sound anymore but I didnt drive far. I moved the track off than back on. Hope it did something lol
Old 07-31-17, 04:23 PM
  #2048
caverman
caverman's Avatar
I did a headlight restoration. The headlights were slightly faded when I got it. I tried using just Plasti-x polish but it didn't do to much. I had the sand paper and clear spray left over from doing my LS so I spent a couple hours (and a few beers) and just knocked it out. They look a heck of a lot better. I didn't think to take a picture before I started but I got a picture when they were about half way done and then afterwards.
Attached Thumbnails What did you do to your GS today?-20170728_182812.jpg   What did you do to your GS today?-20170728_201559.jpg   What did you do to your GS today?-20170728_201609.jpg
AirRideFan (04-15-19)
Old 08-02-17, 08:22 PM
  #2049
LexLova
LexLova's Avatar
that unit was possibly bad , it shouldn't be doing that. I just did the bmc swap , it brakes great , no buzzing no nothing
Old 08-02-17, 08:39 PM
  #2050
GS34B
GS34B's Avatar
Did a little more basic maintenance: replaced the air and cabin air filters. I can't believe they both have such quick and easy access, especially the engine air filter, it's ridiculous how easy it is to check and replace. Even the cabin air filter is easier than my wife's 03 Accord; at least I don't have to completely empty the glove box to get it done.
A few days ago I did a CRC MAF cleaner MAF cleaning to try and help out the common driving hesitation I've experienced and read about, with little result. Measured my MAF resistance which came out low, so gonna go and pick one up tomorrow.
Old 08-03-17, 07:44 PM
  #2051
eicca
eicca's Avatar
Spending $500 on a new OEM power steering pump for this freak-old car just wasn't jiving, so I scored a used GS430 PS pump from eBay for $75. It works great. No more loss of steering at idle and no more leaks!
mate01 (08-03-17)
Old 08-04-17, 04:59 PM
  #2052
cluu
cluu's Avatar
Default C-One strut bar
Bought a C-One strut bar off of a CL member and tried to test fit today. I was aware of the fitment issue against the fuse box. I'm not too worried about this since that extra bit can be cut off but I did not realize I would be blocking off the engine oil cap as well. Any suggestions on what to do here? The bolts from my coilovers have a lot of exposed threads but i don't think running a stack of spacers under the bar would be a good idea.
Old 08-05-17, 08:40 PM
  #2053
caverman
caverman's Avatar
Added a JVC double DIN along with some 4" Kicker speakers in all the doors. The stock speakers weren't too bad but the radio was acting all goofy. They are cheap now and it's worth having bluetooth, USB, and playing Pandora/Spotify.
Also switched out the door lock actuators on both front and rear passenger side. I initially tried the to just replace the motors but ran out of luck with that. Found a guy on eBay that has them professionally rebuilt. I got both shipped for $260. Much easier than having to deal with the rebuild them.
Took off the goofy trailer hitch that was on the car as well.
Here is a quick pick of the radio. It will probably need a sub eventually but it's good enough for now.
Old 08-06-17, 06:16 AM
  #2054
msh34646
msh34646's Avatar
I put in a blower motor and th blower motor resistor. Im still not getting any air coming out of the vents. I can hear the "servo" working but nothing is coming out.
Old 08-06-17, 06:19 AM
  #2055
msh34646
msh34646's Avatar
Cool
Haha. I was thinking of dojng the same thing to mine. I can't even see what station i have on anymore. *shrugs*
Quick Reply: What did you do to your GS today?
