What did you do to your GS today?
Old 05-24-14, 05:03 PM
  #196
DosyBoy
DosyBoy's Avatar
Originally Posted by TigerBrand
Yes, you have to get the key cut. Not bad for a $10 flip key housing off ebay. I just had to transfer the guts from my factory key over.
I hate those, threw mine right in the trash because u can only put the wipers on the first slow setting, u try and put the wipers on another lower setting and it bangs off the fob u can't do it, I had some extremely fun rainy days on the way home from work lemme tell ya!
Old 05-24-14, 06:36 PM
  #197
cmara2k9
cmara2k9's Avatar
Gave mine a good wash and temporarily switched my DRL's back to regular halogen bulbs because I damaged one of my LED's defintley will order more probably from v-leds again but Now my inner headlights are yellow and my HID"s are 6000k, but it makes for an interesting color contrast at night, thats about it lol
Old 06-10-14, 04:36 PM
  #198
BertDeclan
BertDeclan's Avatar
Default What did you do to your GS today?
At this very moment my '98 GS4** is getting a whole new front end's worth of u/l control arms, sway links 'n bar bushings, tie rods, ball jnts, caster arm bushings, steering rack bushings and the obvious alignment. All rubber bushings for ride and quiet. I've waited long enuff. The $ of Conti EC DWS tires made me do it. I'll post on the results in suspension, in a week or so....
Old 06-10-14, 06:18 PM
  #199
pinoiryder
pinoiryder's Avatar
Replace the timing belt. radiator, pulley, belt tensioner, serpentine belt, water pump, coolant,
Old 06-16-14, 09:30 AM
  #200
PRKeus
PRKeus's Avatar
Default patience is a virtue.... RFTM
As we say in Holland: "read the *****ing manual"
For longer times I could not get the navigation programmed, the buttons flattened... Now I found out it does that when you try to program it when driving.... Sorry... unsafe behaviour...my bad
When at a standstill, it programs perfectly...
Also found out that the buttons on the keyholder actually DO work for the windows and the trunk... push it longer than 2 secs and it does what it promises....
On the ToDo-list..... implement Dension iPod-unit.... waiting on materials...
Old 07-02-14, 07:19 PM
  #201
JJaySilver
JJaySilver's Avatar
Fog light mod I did a few days ago:
Old 07-03-14, 02:27 PM
  #202
Miami-SC
Miami-SC's Avatar
[QUOTE=JJaySilver;8609574]Fog light mod I did a few days ago:
How did you do that? Thanks in advace...
Old 07-03-14, 04:10 PM
  #203
ThomasGS4
ThomasGS4's Avatar
Timing belt, tensioner bearings and rollers, water pump, drive belt, camshaft seal, crank seal, thermostat, valve cover gaskets, spark plug seals, and a coolant reservoir tank. I'm sure I'm missing a few things too.
Old 07-03-14, 06:39 PM
  #204
JJaySilver
JJaySilver's Avatar
[QUOTE=Miami-SC;8610769]
I followed BananasGS intructions on how he did his:
http://bananags.grantham-international.com
Scroll down and click on #10 Override foglight switch.
Only change I did was use a 10 gauge wire instead to avoid melting plastic, and the same size wire as shown in his tutorial for the ground wire that connects to that green wire under steering wheel. Very simple.
The only thing I don't like is when my fogs turns off when I turn off the engine on auto. I'm going to move my wire to another fuse location that will allow me to manually turn on/off my fogs anytime, and turns off on its own along with the headlights in auto mode like it always did.
I also disabled my DRL's today; I liked them on, but my fogs are my new DRL's most of the time, and it looks nice with the city lights on too. Next I'll find a way to keep fogs on when hitting the high beams .
Old 07-03-14, 11:51 PM
  #205
Sphan519
Sphan519's Avatar
New Exhaust and Taillights.
Old 07-03-14, 11:55 PM
  #206
aneidiaz
aneidiaz's Avatar
--- Where'd you get the L Tuned tips from buddy?? Very nice! Enjoy bro!
Old 07-04-14, 12:52 AM
  #207
Sphan519
Sphan519's Avatar
Thanks! I got em from another fellow ClubLexus member.
Old 07-04-14, 05:27 AM
  #208
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
wow Parker . did the dealer do this or independent shop? good for another 100k miles on your mint GS 400
Old 07-05-14, 01:57 PM
  #209
wbmx1981
wbmx1981's Avatar
I replaced the vvti pulley that was leaking.
Old 07-05-14, 02:10 PM
  #210
aneidiaz
aneidiaz's Avatar
I finally fixed my air vent problem. Thanks to a few good members. I'm so appreciative of this site. ☺☺☺☺ God Bless Everyone and happy July 4th weekend to everyone and they're families....
Quick Reply: What did you do to your GS today?
