What did you do to your GS today?
Old 09-20-18, 09:37 PM
  #2386
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Originally Posted by GSing430
Hopefully this helps. I was but decided not to. Figure it was best to keep it, not worth selling it. Plan to start driving more often too so, trying to keep it more subtle looking.
always liked how your bumper flowed with the Blitz.. Car looks dope after all these years..
GSing430 (09-26-18)
Old 09-22-18, 01:23 AM
  #2387
lexusbaha
lexusbaha's Avatar
Hello guys ^^
Old 09-22-18, 10:39 PM
  #2388
SoCalSC4
SoCalSC4's Avatar
Finally screwed together some 2x12 pieces so I can get mine in and out of the driveway.
Old 09-23-18, 05:08 PM
  #2389
sbagdon
sbagdon's Avatar
Actually, yesterday... too tired, finally able to post...
Replaced the front upper control arms. Did the struts 3 weeks ago... they were bad... really bad. Not that bad of a job now, as tearing apart and reassembling the struts had already taken place. Just keep pulling, until the struts are out, then remove/replace the upper control arms.
Only issue was the right-front rear bolt... while fighting to get the threads started, the square bolt came out of the hole, on the outside of the strut tower... issue is, to deal with that, the battery has to come out (and took the tray out, for good measure, to clean it up). So if you're doing your upper control arms... be prepared to be removing your battery...!
Much, much nicer, and much, much smoother. That should be everything that can effect the geometry, might do an alignment tomorrow. Still a few little vibrations and wiggles, yet taking care of them, one ball-joint and bushing at atime...
Old 09-25-18, 05:24 PM
  #2390
kevin3344
kevin3344's Avatar
My sunroof was moving slowly for the past couple weeks, so I cleaned and greased the track but that didn't help much. Sometimes it would get stuck and just click. Finally, today I decided to take out the motor and cleaned the contacts. Works like new now.
mate01 (09-25-18)
Old 09-26-18, 09:57 PM
  #2391
GSing430
GSing430's Avatar
Originally Posted by BiGEZ
Car looks great, what rear bumper it that?
Thanks. Bumper is Balsarini
BiGEZ (09-29-18)
Old 09-27-18, 01:19 PM
  #2392
dreamcar88
dreamcar88's Avatar
Got an ol alpine california amp, type e sub and wiring kit for 70$ and got it installed 100$. Couldnt pass that up. Crazy how cheap used car audio is
Old 09-30-18, 12:00 AM
  #2393
anniverse
anniverse's Avatar
I replaced my Crankshaft Seal, both Cam Seals, VVT O-Ring, ECT Sensor and Coolant Temp Sensor
after I had previously changed my Water Pump, Timing Belt and T/Belt Tensioner.
I plan to change the PCV Unit next.
Old 10-02-18, 12:52 PM
  #2394
100bajan
100bajan's Avatar
Past 2 days:
Replaced front and rear passenger side Door lock Actuators. #BigHandsMakeTheWorkerGoOUCH!!! lololol
Old 10-02-18, 03:07 PM
  #2395
n1ck
n1ck's Avatar
This is what happens when you ask a drift shop to weld up your exhaust
Old 10-02-18, 04:02 PM
  #2396
LexLova
LexLova's Avatar
not bad
Old 10-02-18, 04:10 PM
  #2397
604GS400
604GS400's Avatar
Originally Posted by 100bajan
Past 2 days:
Where did you get the actuators from and do you mind telling me the part numbers? Thanks
Old 10-02-18, 08:29 PM
  #2398
n1ck
n1ck's Avatar
Mike from Luxious Auto can hook you up with actuators.
Originally Posted by LexLova
not bad
Looks great man. That color combo looks so good.
Old 10-03-18, 10:13 AM
  #2399
shwalker07
shwalker07's Avatar
Modified the front stock speaker boxes to fit 6.5" speakers. Did have to move and relocate the bass tube inside the unit. I originally bought those wood cutouts but I noticed mold start to grow on them so I tossed them out. Working on the rear ones next.
Old 10-03-18, 11:28 AM
  #2400
tmf2004
tmf2004's Avatar
After 14yrs and 45k miles later i replaced my leaky Tein Coils. Three were leaking and one looked bent by the piston. I can't say enough how great these coilovers were all these years. The GS is still pushing with 96k miles. Next up is paint the front and rear bumpers.
Quick Reply: What did you do to your GS today?
