What did you do to your GS today?
Old 11-02-15, 10:01 AM
  #856
RamAirRckt
RamAirRckt's Avatar
I went with 245 45 17 on my rims, and ride isn't a problem.
My speedo is still off (around 5-6% high), but is almost spot on with 215 60 16's. I went to the 245 45's over 235 45's just for the speedo and it gives a small extra sidewall to protect against curb rash if I got to close.
It helped speedo, but not as good as I had hoped...
Originally Posted by 1QWKGS4
I running 245/40-18 and its very balanced tire, good ride, it handles well and performs like 35 series tire without the harshness.. I use to run 245/35-19.. that's more harder and a bit rougher.. 45 series, i believe would be more cushion but you will out of spec.. the smallest 45 series you can get will be 225/45-18 which is 26" rolling diameter which .3 inch taller than 245-40-18..
I know this because I'm Planning to run 225/45-18 because i have a short rear axle ratio 3.77 rear and my rpms are close to 3K cruising 80mph on the hwy.. if I went with a taller tire it will lower my rpm's. Thats the only real purpose for going out of spec.. I would stay with stock size if you have stock rear axle because going with a taller tire with stock rear ratio with slow up your acceleration..
Old 11-02-15, 10:10 AM
  #857
1QWKGS4
1QWKGS4's Avatar
Thanks Ram, but we were talking about 18's? i think.
The stock GS tire is actually 25.7" tire which is same with running 225/55-16 on the car with 16's..
The GS400/GS430 with the upgraded wheel package has 235/45-17 which is lower 25.4.. so actually the 235/45-17 is under the spec for better acceleration..
the 245/45-17 that you're running is actually stock spec but they use a smaller tire for some reason from the factory. Its same as if your running 245-40-18. both 25.7" rolling diameters as well as 225/55-16 stock 16's..
Old 11-02-15, 10:16 AM
  #858
SurfsUP
SurfsUP's Avatar
Put some Rays TE37's as temps until my cracked Work Equip gets repaired by VR.
Doesn't look too bad but still too small and narrow.
Old 11-02-15, 10:20 AM
  #859
1QWKGS4
1QWKGS4's Avatar
RAM: You were right about the 16's, If I remember correctly the very first GS's with 16's came with the 215/60-16's on the car for some reason.. the spec on that is 26.2" wow thats a tall tire for stock and then later they went with the 225/55-16 which is 25.7 tire..
Edit: I just look at my manual and confirm with Tire rack.. that 215/60-16 was stock tire on the GS300, while the 225/55-16 is stock tire on GS400. I think factory put on 215/60-16 on the GS300 is because the GS300 came with 3.92 rear axle ratio.. If they ran the other sizes their hwy rpms would be real high is my guess why the different sizes...
Old 11-02-15, 02:49 PM
  #860
Miami-SC
Miami-SC's Avatar
Gave it a wash on Sunday...
Old 11-02-15, 08:08 PM
  #861
SoCal Cyco
SoCal Cyco's Avatar
why have I not seen this car before?? any pics of the front?
Old 11-03-15, 05:53 AM
  #862
JJaySilver
JJaySilver's Avatar
Originally Posted by alexulan
I'm over these tails, they look nice and all but I rather have those JP tails and throw some JDM Astar LED bulbs in them and call it a day.
Old 11-03-15, 09:49 AM
  #863
SurfsUP
SurfsUP's Avatar
SoCalCyco-The previous spent 4 years building this GS and I traded my 89 R32 Skyline for it. PO owns a shop here in Vegas and spent over $40k on it. Its also got a swap from an Aristo, fully built 2JZGTE.
Old 11-03-15, 10:48 AM
  #864
SpectraBlu
SpectraBlu's Avatar
Car looks sick! I gotta quit lagging and rebuild my equip's to the proper size.
Old 11-03-15, 04:44 PM
  #865
nelson09
nelson09's Avatar
^^^whips on point, TE's don't look bad on there, besides what you mentioned but the equips FIT!
Old 11-03-15, 08:12 PM
  #866
SoCal Cyco
SoCal Cyco's Avatar
very nice surfsup!!!
Old 11-04-15, 02:15 AM
  #867
clos430
clos430's Avatar
Slapped on some 305's in the rear and resurface all 4 rotors.
Old 11-04-15, 09:26 AM
  #868
PandaGS300
PandaGS300's Avatar
Dude that bumper is legit!!!!!!!
Old 11-04-15, 09:49 AM
  #869
RamAirRckt
RamAirRckt's Avatar
305's fit? Nice!
Old 11-04-15, 10:53 AM
  #870
krdp2GS
krdp2GS's Avatar
LAWD HAVE MERCY! This is b-e-a-utiful!
Quick Reply: What did you do to your GS today?
