p0440 p0441 p0446 dtc codes on my 02 gs300
Hey Guys I have a 02 gs300 and am getting 3 dtc codes p0440 p0441 p0446. I googled the codes and saw that alot of the causes are hoses disconnected or cracked. I replaced a cracked hose at the top of the engine under the plastic engine cover. I also noticed another hose that is behind the air filter box that was cracked replaced that. What other hoses should I be looking for? Thanks.
iModerate
I suggest you search the 2GS forum for previous posts and resolutions to these codes. I suggest you search each code one at a time (more results + info) or all three together (less results). These are relatively common codes which many members have been able to isolate and resolve. Let me know if you need assistance with searching the 2GS Forum. I will be happy to help you out.
![](https://www.clublexus.com/forums/attachments/gs-second-generation/273519d1361224578-check-engine-light-on-snap-2013-02-18-at-13.54.24.jpg)
