Has anyone rebuilt their brake calipers
I recently found out that my drivers side brake caliper is stuck. I have been doing some research and I found that Lexus sells a cylinder brake kit part # 04478-30240 but I am unable to find a DIY for rebuilding the GS300 stock brake calipers using this kit.
Has anyone done this and how easy/difficult it is as a DIY?
I also see autozone selling rebuilt calipers but i am wondering the quality of those, has anyone has any experience with the autozone calipers?
I was also considering going the LS400 BBK route but I have L-Tuned Springs and Shocks and running stock 16" wheels so I that is out of the question for now.
if this is in fact the pistons and not the slides it will be easier to get a remain unit. If its seized there is corrosion so not only will it be a ***** to get out but you will have to polish the bore and replace the piston itself depending on how severe it is.
typicaly you can pull a good piston with compressed air or pliers...wont work in your case. stick to a reman and be happy.
newyorksc
Wheels, Tires & Brakes Forum
09-24-07 03:24 PM
