steering wheel makes clicking noise when i turn
anyone know what the problem is? when i do full turns left or right theres this grinding/clicking noise coming from steering wheel assembly.
The clicking is during the turning right? not when you are not moving the wheel?
There is likely a bearing or part of the column/ spline where the grease has worn out.
Open up the bottom dash, and grease up all the parts of the column that connect with room-temp lithium grease (real grease, not a spray). If you see any old grease, clean that up so you can work in new grease.
For the column shafts, you will want to try to really work the grease into the splines or contact points by hand, like handpacking a wheelbearing or for the non technical trying to get toothpaste back into the tube. You may need to go for a drive and work the steering wheel, and repeat to get more grease in there..
funny cuz it started to happen after i took off my calipers to get my disk resurfaced. ill probably check it out. thanks
It's a 100 part if so.
no haven't removed the steering wheel, probably gonna do that later today. i've been doing some searches on the clock spring and i don't think thats it. the noise in my car kinda sounds like a spring is loose. clock spring problems have that squeaky noise.
Off topic and apologize for thread jack, but my steering wheel is not aligned straight and hear clicking when turned fully left/right. Also there is this buzzing sound from inside steering wheel or instrument cluster area when the car is on. Happened after I removed steering wheel.. what should I be looking out for in this case? Thanks.
rocketpope
08-31-18 08:53 PM
Yg_green1
GS - 1st Gen (1993-1997)
16
01-01-08 09:40 PM
purebliss
ES - 5th Gen (2007-2012)
10-09-06 08:28 AM
