Temperature needle at a tad bit passed half...is this right?
Old 03-19-13, 05:21 PM
t0nyt00nz
t0nyt00nz's Avatar
Default Temperature needle at a tad bit passed half...is this right?
For all you gs300 owners..where does your temperature needle sit at..at normal temperature? Mine stays a little bit past half...is this normal? Bought it like that
Old 03-19-13, 05:47 PM
GS4hunnit
GS4hunnit's Avatar
Mine is like that too. Did you flush it or replaced your radiator recently? It seems to be working find though.
Old 03-19-13, 06:30 PM
DosyBoy
DosyBoy's Avatar
Mine is identical also, A dude I know with a 400 is the exact same also...
Old 03-19-13, 06:37 PM
robrike
robrike's Avatar
Hmm, on my 98 GS300 it sits a tad below half. I will be changing the timing belt and all other recommended items so maybe a new thermostat will change that. This was my wife's grandmothers car before we bought it and even when it had 50k miles on it the temp gauge was a touch below half. My gauge might be off. Runs fine and heat is plenty hot.
Rob
Old 03-19-13, 06:49 PM
SC2JZ300
SC2JZ300's Avatar
Mine sits a tad below the half way line @ OPT
Old 03-19-13, 06:55 PM
Johnny Rad
Johnny Rad's Avatar
The heat-o-meter in my '02 GS430 reads a tad below half.
Old 03-19-13, 08:54 PM
t0nyt00nz
t0nyt00nz's Avatar
Hmmm...it might be normal then..i havent flushed it or changed fluids.nothing like that..so maybe just needs a thermostat sensor
Old 03-19-13, 09:09 PM
ForeignVee
ForeignVee's Avatar
Perfectly normal
Old 03-19-13, 10:22 PM
GS4_Fiend
GS4_Fiend's Avatar
it all depends on your thermostat rating temperature. if you got a cold type it will read below normal.
Old 03-20-13, 01:44 AM
PlatGS3
PlatGS3's Avatar
My 300 stays exactly at half.
Old 03-20-13, 03:47 AM
SorrGwa
SorrGwa's Avatar
to be honest, the temp gauge is not that accurate. so long as your riding around the 1/2 mark, and not going upwards past 2/3s or even 3/4s, your still good. just keep an eye on it.
some will read below the 1/2 way mark, some above it, so long as its around the 1/2 way, its good.
Old 03-20-13, 10:35 AM
chubz
chubz's Avatar
mine is like that as well. must be normal.
Old 03-20-13, 11:37 AM
talbott
talbott's Avatar
I have a GS4 and mine is right above the half line
Old 03-20-13, 06:36 PM
LexiBlue
LexiBlue's Avatar
Its normal mine is like that also.
Old 03-21-13, 12:41 AM
Riksgs808
Riksgs808's Avatar
My 300 is a hair above half also. Im glad that seems to be normal now. I was kinda worried boutit.
sabbates
GS - 1st Gen (1993-1997)
15
06-22-17 01:52 PM
98LSFan
12
07-27-16 07:01 PM
mbaker7
01-23-14 02:28 PM
SEBASS
15
01-09-10 08:12 PM
levinsoy
11-12-06 02:31 PM
Quick Reply: Temperature needle at a tad bit passed half...is this right?
