Best Led Tail Light
Old 03-29-13, 03:38 PM
  #31
nGooo
nGooo's Avatar
Originally Posted by RCFC89
Looks great. What exhaust is that? And how loud is it? I'm looking for something that sounds deep and smooth but is not loud where it drowns out the whole interior cabin with exhaust growl.
5zigen mega fireballs. these with resonator delete will give it nice deep tone. well depends on if you have a 300 or 400/430 as well.
Old 03-29-13, 04:44 PM
  #32
RCFC89
RCFC89's Avatar
I have the 430. Do they make them were the factory resonators are still present?
Old 03-29-13, 04:54 PM
  #33
nGooo
nGooo's Avatar
these are just axle backs. so deleting your resonators is your option.
Old 03-29-13, 06:57 PM
  #34
RCFC89
RCFC89's Avatar
Damn they are pricey for just being axle back but probably the best option for looks and for me wanting something more subtle noise wise. Thanks for the info.
Old 03-30-13, 11:36 AM
  #35
pmlexus
pmlexus's Avatar
I have the same set up on my GS but I have the universal mufflers and I love the sound. It is deep but not too loud in side the cabin. I love the sound in the morning when I first start her up, and it has the deep tone. I recommend that you get them if you can find them still I know that they are now discontinued, I paid $600 for mine and they were used.
Old 03-30-13, 11:58 AM
  #36
RCFC89
RCFC89's Avatar
Thanks bro. I've built several cars that were just too loud. Especially my most recent build FC rx7. This is a luxury car and I want to keep it that way. I'm currently trying to source the 5zigen but if I have no success I'll go with the JP Type 3.
Old 04-02-13, 02:30 PM
  #37
pmlexus
pmlexus's Avatar
My exhaust is currently using the factory resinators and the tone is perfect, I have was orginaly going to just have them removed but Im glad I didnt. The key to a good sounding exhaust is the resinators that you use.
Old 04-03-13, 08:55 AM
  #38
RCFC89
RCFC89's Avatar
Depo before and afters.......................
Old 04-03-13, 08:58 AM
  #39
RCFC89
RCFC89's Avatar
Also install on the Depo's were very easy. Just pull out factory housing with harness intact. Insert new Light and snap Depo harness in. I also didn't use the resistor boxes as recommended. Simply pulled the gauge cluster and removed the bulb.
Old 04-03-13, 09:10 AM
  #40
MrG4Life
MrG4Life's Avatar
Did you do the tailight mod for your Depo's?
Old 04-03-13, 09:22 AM
  #41
RCFC89
RCFC89's Avatar
Mod? .................
Old 04-03-13, 09:49 AM
  #42
pdxgs
pdxgs's Avatar
Those depos look so clean on a white car. The taillight mod consists of cutting a resister in the taillight sending unit so the light-out bulb in the dash doesn't light with LED tails. Easier than pulling the dash bulb.
Here it is: https://www.clublexus.com/forums/lig...l?ref=esp-link
Old 04-03-13, 10:39 AM
  #43
RCFC89
RCFC89's Avatar
Thank you. I beg to differ on pulling the left side of the trunk apart and cutting the wire being easier. It took me about 5 minutes to pull the bulb. The gauge cluster comes out quite easily.
Old 04-03-13, 12:39 PM
  #44
MrG4Life
MrG4Life's Avatar
Actually I meant ****-ADKT's thread... it works with the DEPO tails too:
https://www.clublexus.com/forums/6929573-post9.html
I just put a piece of electrical tape to cover the "light-out" indicator on the cluster since I'm not running resistors either.
Old 04-03-13, 01:39 PM
  #45
RCFC89
RCFC89's Avatar
Its so easy to remove the cluster. Just pull 3 circle plastic outer piece straight out. Disconnect the odometer reset wire and put it aside. There are 2 top and 2 bottom screws holding the gauge cluster in place. Remove them and pull cluster out and lay it on its back on the steering column without undoing any wire. The brake light bulb is the second one from the left on the bottom. Take a phillips screw driver and remove the bulb and reassemble. It takes no more then 5 minutes.
Quick Reply: Best Led Tail Light
