Key fobs work randomly
Two months ago I had my car in the body shop because someone hit my back passenger door. After picking it up my Key fob's will only work after I manually use the key. After walking away out of range, I will have to manually lock or unlock for them to work again. I have replace batteries in both key fobs and no luck. I am baffled that they only work after using the key manually to unlock or lock.
I dont know what to do to fix this other than taking it to the stealership and that is a last resort.
I will take my door panel off and check if they broke the end of the cable. That could cause the key fobs to work randomly??? Weird.
Yes that is where I was hit. I was under the impression that the dealer had to reprogram the key fobs. I found the DIY to reset so I will try that in a few.
gmac1337
09-22-08 08:30 PM
