calling all q45 retro fitters need some help
Old 04-17-13, 08:10 AM
sakataj
sakataj's Avatar
Originally Posted by Advil4u
Lol how do you know my name?
Originally Posted by sinistervr
you follow me and i follow you on instagram
this is what you should have said Adam
Old 04-17-13, 08:41 AM
Advil4u
Advil4u's Avatar
Ahhhhh adam gotcha so u already started seeing the pics of how I opened em up last night
Old 04-17-13, 09:37 AM
Advil4u
Advil4u's Avatar
Lol I belive u r underestimating the sneakiness sr
Old 04-17-13, 08:14 PM
abounly
abounly's Avatar
I did a write up on my FX-R retrofit. Look for it.
Old 04-17-13, 09:34 PM
Advil4u
Advil4u's Avatar
Ok every retrofit I have read up on does not say how they cleaned off the silicone/sealant off the housing the reseal any sugestions?
Im gonna stick the housing in the oven and losen it up to clean it see how that goes
Old 04-17-13, 11:14 PM
abounly
abounly's Avatar
Just scrape it off, heat it with a heat gun.
Old 04-18-13, 12:08 AM
Advil4u
Advil4u's Avatar
I dont have to take it 100% off right I mean tat would be impossible then re seal them with new bond
Old 04-18-13, 06:52 AM
77i9
77i9's Avatar
I just reused the old sealant.
Old 04-18-13, 10:40 AM
Advil4u
Advil4u's Avatar
Yea I tought about that after scraping off alot of it so im forced to use new one on this one headlight the other I will pop it on the over to get the sealer soft again and add a bit new sealer on the channel and clamp together
Old 04-18-13, 10:42 AM
Advil4u
Advil4u's Avatar
What type of sealer did you guys use please be specific so there is no confusion for me And other who will be doing a retrofit in futer also im getting all my pics in order for the write up
Old 04-18-13, 10:55 AM
Kyle Harty
Kyle Harty's Avatar
I believe its retrofitsource that sells rolls of butyl rubber sealant, around $15 IIRC. Basically the same as the factory glue except black. Heat sensitive like the factory glue so if you need to reopen them it won't be a problem. I've used this on a couple sets.
Old 04-18-13, 11:26 AM
Advil4u
Advil4u's Avatar
Hmmm thanks so these are strips that I am assuming u put in the chanel and re heat in oven to soften and just place the lens back and clamp while it cools?
Old 04-18-13, 11:44 AM
Kyle Harty
Kyle Harty's Avatar
Correct, that's the procedure, although I didn't feel the need to clamp them, it firms up and holds pretty quickly, certainly wouldn't hurt to do it. One roll is more than enough to do both lights.
Old 04-18-13, 01:26 PM
Advil4u
Advil4u's Avatar
Thanks a million
Old 04-18-13, 03:28 PM
abounly
abounly's Avatar
Yes, I did use butyl from TRS. I didn't bother reusing the old seal, being afraid that it would condensate. You can do at least 3-4 pairs of headlights for 15 bucks.
Quick Reply: calling all q45 retro fitters need some help
