Man i have this same noise! pretty much only when i almost come to a stop and am braking. If i jack the car up you can't reproduce the noise. It's annoying only because people are like, wtf was that?
QUOTE=Sevenevez;7915782]yup checked that, has plenty of clearance as far as i see[/QUOTE]
Ok. Did you check the sway bar end links? I should of listened to LUXURYGS3 .. I forgot to check them and so did my mechanic. He called me and told me he forgot to check them. Tomorrow I will check them, hopefully thats the problem.
I'm having the same issue with my 01 GS430, so I took the GS to my local Big O Tires and they inspected all the suspension components and they also couldn't find where the popping sound is coming from.
I have the same issue with my 02 GS300. Had a mechanic check it out and he figured that it is the brakes. I get the sound when I back out of garage in the morning - first time I apply the brakes....CLUNK. Then after I shift in to drive...the first time I apply the brakes...CLUNK. Seems the brake pads shift. Sound doesn't come again until I apply the brakes again in the opposite direction of travel. He checked all suspension components and everything is fine. Unfortunately he doesn't have a solution.
