ML Stereo Problem - volume won't increase
Old 05-26-13, 06:28 AM
komodo
komodo's Avatar
Default ML Stereo Problem - volume won't increase
Hey Guys,
Need some help from ML audio guru's.
I own a 2003 GS430 with factory ML & Nav. Stereo is stock.
Problem:
- when I turn up the volume on the factory head unit, the sounds "turns off" but the head unit stays on - I'm only losing my audio at that desired sound level. When I turn down the volume button, the audio does come back on, but it only plays at low audio level. I am not getting the volume up much when this happens. So, it happens at lower audio levels.
Also, this happens regardless if the car is running or is in the garage parked. It's not an overheating issue on the amp - I have checked.
I have also checked all the speakers - none are bad (surprisingly). No cracks or blown voice coils.
Luckily, I have a factory spare ML amp (for the GS430) that is 100% normal, and when I plugged it in, the same symptoms occur. Ok, now I'm really confused.
If it's not a bad speaker, or a bad amp -then what is causing the volume to go out when you try turn it up?
Thanks for your time; I've been searching all over CL for a similar issue and can't seem to find it.
Old 05-26-13, 07:39 AM
iToaster
iToaster's Avatar
It sounds like the switch on the radio is bad. If this is the case, it is possible to replace it, but finding the proper switch and removing the old one would be challenging.
Old 05-26-13, 07:51 AM
komodo
komodo's Avatar
Hi IToaster,
What "switch" are you referring to?
Thank You!!
Old 05-26-13, 12:31 PM
Revive
Revive's Avatar
I have a similar issue with my ML audio switch. It's finicky and sometimes volume turns down when I try to turn it up and vice versa. Other times it won't do anything. For mine it's definitely just the switch because I can pull on it a little bit and get it to work properly.
Old 05-26-13, 12:48 PM
komodo
komodo's Avatar
By "switch" you mean the volume button?
Old 05-26-13, 09:15 PM
JEBAAY
JEBAAY's Avatar
The volume/on-off switch
Adziu
IS F (2008-2014)
24
05-11-18 06:57 PM
HaerdenC
01-11-18 02:17 AM
maxx430
09-16-14 04:24 PM
biggieTX
03-02-10 11:47 AM
Quick Reply: ML Stereo Problem - volume won't increase
