Need some help with my 1998 gs300
Hey everyone, I got this 1998 gs 300 used for about 6 months now and since then I have replaced
3 fuel pump ecu (all used) and 2 fuel pumps (new)
Car just died again im lost on what to do now. Is there something I should check out that would be causing these problems?![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Also where should I go from here? got a bad ecu and a bad fuel pump again.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
advice much needed Thank you in advance.
Hey mate,
Check if there are any diagnostic codes. Bridge E1 & TE1 on the diagnostic plug in the engine bay and look at the engine light on the instrument cluster.
This will hopefully lead you in the right direction.
Lexus082
Performance & Maintenance
05-31-12 11:34 AM
sebasc300
SC- 1st Gen (1992-2000)
22
02-05-11 02:33 PM
