PCV Valve Question.
06-25-13 | 06:40 PM
PCV Valve Question.
Is the PCV valve suppose to spin freely? Im in the process of troubleshooting the P0171 code and I was checking all hoses in the engine bay. Thanks.
06-25-13 | 07:05 PM
06-25-13 | 08:55 PM
Im sure your checking for vacuum leaks; but have you tried simply cleaning the MAF sensor, that may do the trick.
06-26-13 | 09:47 AM
looking at fuel trims numbers will definitely help you with this.
06-26-13 | 05:54 PM
This is what the code is from a AutoData website:
EOBD code: P0171
Fault location: System too lean, bank 1
Probable cause: Intake/exhaust leak, AIR system, MAF/VAF sensor, fuel pressure/pump, injector(s), HO2S
bwaller86
10-30-18 02:20 PM
stargo
RX - 1st Gen (1999-2003)
03-09-12 05:53 AM
jimbo22s
Maintenance
12-24-08 02:58 PM
bjz3638
10-21-07 10:08 PM
