Gs300 2nd Gen Radio backlight out
Hello All,
I have done some research trying to find as answer to my problem but i guess im not using the right key terms in my search...
The problem that im having is that my radio back lighting is out. i found a post recommending to change "Radio NO2" fuse (7.5).. I have not replaced the fuse but i just checked it and it looks fine.. is there any other possible fuse that correlates with this problem???
fyi:
recently changes "dome" fuse
as well as "panel" fuse
I have an 2001 GS 300 btw
fyi:
Loves Snickerdoodles!
Sounds like a similar issue described in the thread below. Maybe you can PM the op (original poster) to see if the issue was resolved.
https://www.clublexus.com/forums/lex...-went-out.html
