how much can I sell my full powertrain setup? engine,transmission,rearend.
I bought a 98 blk/blk gs400 with 216,xxx(now 219) miles after buying I put on brand new starter(which it needed) has a new alt within last year, then had full timing belt service with all oem parts, water pump,thermo, cam seals, crank seals, timing belt,tensioners, recent oil change, transmission change, rearend change. Everything runs like a top motor idles so quiet and transmission shifts smooth. Burns zero oil and does not smoke surprisingly with mileage. Havent done leakdown test but wanting to sell:engine,transmission,driveshaft, and rear end. Only one issue at all is a leaky power steering pump. I got a hook up on a very low mileage setup. So curious what I should ask. Its all in the car still, being used as my daily.
Anyway I have a full OEM set of brand new motor and trans mounts if you or anyone else needs them at a great price.
Heres the Link,
https://www.clublexus.com/forums/2ge...ml#post8027177
THANKS!
Im sure none has been done either since not at first interval time yet but no problem once out of car. Nothing wrong with mine but id like to rock my car for years to come
I have a great running high mileage motor and trans now for sale. Runs perfect, zero oil consumption seriously, and brand new seals,water pump, thermo, timing belt, etc..
HD-GS4
06-01-05 12:01 AM
