Radiator and A/C fan help
Hello guys, I have a lil problem not even sure what the hell happened because it was working fine the day before. My fans do not work and my car goes above the normal running temp. I check the fuses and relays all seem good. I turn on the ac and set the temp high but the fan does not come on. However I removed the plug from the sensor or switch located at the bottom tank of the radiator and bot fans come on as soon as I turn the car on.
Would this suggest that the switch or sensor is bad???
I hope so man. sad part is I bought it yesterday but they gave me the wrong part at the store... aint that a *****. have to change it today and try later this evening.
Mvinhie
10-08-13 08:55 AM
