odd problem
Old 09-05-13, 04:04 AM
Echo419
Echo419's Avatar
Originally Posted by Bhubb18
O2 sensor error is usually a symptom, not the cause
makes sense because I changed them last night and this am on the way to work the CEL came back on.
so to recap I've replaced the Fuel pump/filter, O2 sensors and switched back to a stock airbox. I'm going to pull the code again after work to see if it's the same.
if I get the same codes I'm thinking the fuel pressure regulator and bypass relay?
Old 09-10-13, 06:38 PM
Echo419
Echo419's Avatar
Well I replaced the fuel pressure regulator. Still the same problem
Old 09-10-13, 07:47 PM
Shagnasty
Shagnasty's Avatar
Did you check the Oil control valve? Sometimes the screen can get clogged up.
Old 09-11-13, 05:28 AM
Echo419
Echo419's Avatar
oil control valve? how would that cause cycl #1  to run rich?
also how are the cylinders numbered on this car? I've done a ton of searching with 0 results that are of any use.
edit: I hate this car. it is about impossible to find anything of use online for it.
/rant
Old 09-11-13, 11:25 AM
BRAD123
BRAD123's Avatar
Stop throwing money at it and bring it to the dealer...it will probably be cheaper in the long run. Have them diagnose but not fix if you want to save as much as possible.
Old 09-12-13, 11:33 AM
Echo419
Echo419's Avatar
Dropping it off at Nalley Lexus Monday
Old 09-12-13, 12:34 PM
BRAD123
BRAD123's Avatar
Good Luck...let us know what they come up with.
Old 09-25-13, 06:14 PM
Echo419
Echo419's Avatar
Well I think I found the problem. so I went to pull the PCM and guess what. There is a unit quoted into the PCM labeled Swift Racing Computer. I suspect this is the source of the problem. I will be calling them in the morning.
Anyone have experience with these?
Old 09-25-13, 06:41 PM
pbennett
pbennett's Avatar
I had a similar sounding problem with my older, 95 Lexus. It was "smothering down" for a lack of a better term...It would run fine, then just slow down to a halt. Let it sit for about 10 minutes, and it would run fine for a while, then do it again.
My mechanic said that it was the power steering fluid. It needed draining instead of just replacing. After he did that, he let it sit and run for a couple of hours. He said it only stopped once and after he cleared a code, it didn't stop again. The car is running again just fine. I'm not mechanically savvy, so I hope this makes sense. The fan was running, but it could be easily stopped with your hand. After he replaced the power steering fluid, the fan kept it's normal speed. The computer would think it was over heating and shut it down. I have no clue why the power steering fluid made a difference. Just telling ya what he said....
Old 09-26-13, 04:20 AM
Echo419
Echo419's Avatar
Originally Posted by statix04
Sounds to me your cars putting itself into safe mode, sure its nothing to do with the tps or tb?
dealer tested the TPS and it's good. The throttle body is almost new. like 20K or less new.
your MAF sensor could be dirty/gunked up man, causing it to run rich, have you checked it? what kind of intake filter are you running? OE? after market with oil?
I was running an aftermarket filter with oil but I changed that out with a stock airbox and newer MAF. that didn't fix it but it hasn't died and left me stranded since. however the CEL was still present and until recently the car would hesitate very bad on a launch with any real amount of power.
what's strange is I let my dad take it to "his guy". he had it for a few days said it was something internal and would need thousands. well after we picked it up the car has been running like a champ since. I mean better than ever before, very strong.
power steering fluid? yeah, I don't think so. I think you just got lucky and the problem went away.
Old 09-30-13, 08:27 AM
Echo419
Echo419's Avatar
here's the intake and ECU that's on the car.
http://www.swiftracing.com/SRT/item.aspx?id=86
also my friend I bought the car from saw it on this forum before he bought it. I need to check that out. I'd like to ask him who wired up this thing. very shotty work.
tommy152
05-24-16 03:16 PM
tomtheslac
16
09-09-10 07:45 PM
lexhere27
Performance & Maintenance
12-28-09 08:16 PM
dondoola
06-22-08 07:49 PM
Curry
04-12-08 07:57 PM
Quick Reply: odd problem
