GS 430 air leak in pass window
#47
Originally posted by DJC
Ski - Thanks for the suggestion on the body plugs underneath the car. I look under the passenger side and sure enough there was one missing. Took it into the dealer and had them install a new plugs with silicone (they said there were additional ones in the back missing as well) and it quieted the wind noise down to almost nil. However, at certain times and moving in certain directions against the wind, I can still hear the noise although not nearly as prevelant as before. This is in contrast to the driver's side which is virtually silent. I'm still searching for additional leaks where it could be coming from. Perhaps the sideview mirror? If anyone has further ideas/suggestions/experiences, please pass along.
Thanks,
DJC
Thanks,
DJC
#49
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
i installed the 90950-1959 in the front and they cut the road noise at least in half.
that is on a1999gs400.
i'm pretty sure the rear ones are 90950-1580. i had them in hand and looked at the wrong hole and returned them. today i spotted the correct hole and am 90% sure the 90950-1580 will plug it up
anyway great way to make the car quieter and thanks to everyone for doing all the work.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
ivan
3dog
ivan
3dog
#52
I have intermittent wind noise from the passenger side window as well. I know it's from the window and not the floor plugs because I can make it go away by repositioning the glass. Not to mention that I ran a diagnostic test with a friend... I actually FELT the wind coming through the seal. Mine is coming from the top corner of the window...
#54
#55
sounds like air leaking in from passenger rear window 55 to 60 mph had it back to lexus 3 times they cant find any problems any answers out there thanks tom....... could the sun roof be leaking air instead ??
gs3andahaf
03-16-13 10:29 AM
