Power Steering Failure 1998 GS 400
Ever sence I flushed my power steering mine got all stiff on me .I took it to several different mechanics,THey all say the same thing nothing is wroung wit it its all my head.I no somethings not right.and Im starting to wish i bought a bmw or Benz.
1. Remove PS reservoir cap.
2. Turn ignition key ON to unlock the steering wheel but leave car OFF (Or do you need to start car for this to work?)
3. Jack both front tires off ground (or do you not need to?)
4.Turn wheels max left and max right about 5-10 times. Each time you do this, check for tiny bubbles coming up at the reservoir.
5. Repeat step 4 until you see no more bubbles in the fluid.
If your PS is stiffer than you remember and you aren't just imagining it, then it's likely you got air trapped in the fluid within the system which is causing the problem. The above procedure, assuming I have the details about right, should get rid of the air by letting it bubble up through the lines and out the reservoir.
If you've already done this, then sorry, no idea.
